Digiface AVB
256-Channel 192 kHz USB Audio Interface
Digiface AVB
Products
Digiface AVB
Developed by RME, Digiface AVB is a glance into the future of audio network technology. The device uses AVB, an open protocol developed by the IEEE, to transfer up to 256 channels of audio between PC and audio network. An additional headphone output allows high quality monitoring.
Connectivity and Features
RME USB 3.0
1 x Phones Output
TotalMix FX
ARC USB
Word Clock I/O
Gigabit Ethernet (802.3 compliant)
DC-coupled Outputs (Phones)
Exploring new Ways to transport Audio
RME’s Digiface AVB showcases how audio can be transferred from a Mac or PC into the network and back using the AVB protocol stack. It allows to send up to 128 audio channels for record and playback at 48 kHz / 24 bit sampling frequency and 64 channels at 96 kHz (128 channels I/O AVB) or 32 channels at 192 kHz with quad speed (64 channels I/O AVB).
Channels are organized in streams of configurable size from 2 to 32 channels, which enables connections to all available AVB audio devices on the market (comprehensive compatibility tests pending). The accompanying software package comprises an AVDECC controller, which provides essential functions to discover all AVB devices in a network and manage connections of incoming and outgoing streams. Basic monitoring capabilities are built in. TotalMix FX enables comprehensive routing and monitoring options.
DIGICheck
TotalMix FX and TotalMix Remote
Like all the latest RME interfaces, the Digiface Series also includes the powerful digital real-time mixer TotalMix FX. It allows for practically unlimited mixing and routing operations, with all inputs and playback channels simultaneously, to any hardware outputs.
TotalMix Remote
The Digiface Series includes a dedicated Control Room section with Talkback, Main/Phones, fader groups, mute groups, complete remote controllability via Mackie or OSC protocol, and much more. The Digiface Series does not support DSP based effects (FX) like EQ or reverb.
Additionally RME’s latest software, TotalMix Remote, enhances the power of RME interfaces by enabling remote control via iOS, PC or Mac. With a straightforward set up process — simply enter the IP address of the computer you would like to control with TotalMix Remote and get going — users can quickly adjust any aspect of TotalMix FX on a host system while walking around the studio with their tablet, or from a control room located elsewhere in the facility.
DigiCheck - Test, Measurement and Analysis Tool for Mac & Windows
The Interface comes with RME's unique software tool box for metering, testing, measuring and analyzing digital audio streams. On Mac OS X provides unique functions and features of the spectral analysis of the data calculated in hardware level right through to sophisticated multi-channel level meter. On Windows, an additional multi-track recorder and the display of playback data from an audio software are also available.
TotalMix FX - Mixing/Routing with superior features for Studio and Live Work
Since 2001 TotalMix added unlimited routing and mixing to RME‘s audio interfaces. Its unique capability to create as many independent submixes as output channels available turned it into the most flexible and powerful mixer of its kind.
Find out More
RME USB - Transport audio with lowest latency and industry leading stability
Use your RME audio interface on Mac and PC with reliable, stable, and regularly updated drivers for our products. RME Audio develops its own interface core, it’s not dependent on 3rd parties for upgrades, modifications or bug fixes, so customers can use latest operating systems without interruption or delay."
Find out More
DigiCheck - The Secret Weapon of High Resolution Audio Measurements
RME Audio interfaces not only provide you with a professional digital audio interface, but also with a free available software tool: DigiCheck, for metering, testing, measuring and analyzing digital audio streams.
Find out More
Specs
Digiface AVB
Gigabit Ethernet Port
  • RJ45
  • 100 Mbit/s, 1 Gbit/s
  • Standard port LEDs: yellow connected, green data transmission
  • Supports straight and crossover cables (Auto MDI-X)
  • Up to 16 AVB audio streams
  • AVDECC based exchange of status and control data
  • Network-based remote control of the unit (TotalMix Remote)
Word Clock In
  • BNC, not terminated (10 kOhm)
  • Switchable internal termination 75 Ohm
  • Automatic Double/Quad Speed detection and conversion to Single Speed
Word Clock Out
  • BNC
  • Max level: 5 Vss
  • Level with termination 75 Ohm: 4.0 Vss
  • Internal impedance: 10 Ohm
Output Analog Phones 33/34
  • Dynamic range (DR): 110 dB RMS unweighted, 113 dBA
  • Frequency response @ 44.1 kHz, -0.5 dB: 0 Hz – 20.8 kHz
  • Frequency response @ 96 kHz, -0.5 dB: 0 Hz – 45 kHz
  • Frequency response @ 192 kHz, -1 dB: 0 Hz - 89 kHz
  • THD @ -1 dBFS: - 96 dB, 0.0016 %
  • THD+N @ -1 dBFS: -95 dB, 0.0017 %
  • Channel separation: > 100 dB
  • Output: 6.3 mm TRS jack, unbalanced
  • Output impedance: 2 Ohm
  • Output level at 0 dBFS, 1 kOhm load: +9.5 dBu
  • Max power @ 0.1% THD: 50 mW
Digital
  • Clocks: Internal, AVB, Word
  • Supported sample rates: 44.1 kHz up to 192 kHz
General
  • Power supply: USB bus power
  • Typical power consumption: 1.5 Watts
  • Current at 5 V bus power operation: 300 mA
  • Max power consumption: 2 Watts (400 mA)
  • Dimensions (WxHxD): 112 x 26 x 83 mm (4.41" x 1.02" x 3.27")
  • Weight: 300 g (0.49 lbs)
  • Temperature range: +5° up to +50° Celsius (41° F up to 122°F)
  • Relative humidity: < 75%, non condensing
All specifications are subject to change without notice.
Back
Drivers
Digiface AVB
Flash Update
Release date
Download
Windows Flash Update Tool for MADIface XT/USB/Pro, OctaMic XTC, ADI-2 Pro Series & DAC, Digiface USB, UFX II/III, UFX+, Digiface Dante, Digiface AVB
Update to firmware: (* latest change)
MADIface XT: USB 191 PCIe 56 DSP 42
MADIface USB: 25 (6), 101 (7)
MADIface Pro: 73
OctaMic XTC: 47/26
ADI-2 Pro series: FPGA 267, DSP 128
ADI-2 DAC series: FPGA 81, DSP 62
ADI-2/4 Pro SE: FPGA 72, DSP 40
ADI-2/4 Pro SE: FPGA 209, DSP 40
UFX II: USB 26 DSP 26 CC 15 (A), USB 115 DSP 26 CC 112 (E), USB 206 DSP 26 CC 208 (7)*
Fireface UFX III: USB 20 DSP 21 CC 44*
UFX+: USB 55 DSP 58 Thunderbolt 112 (A), USB 72 DSP 58 Thunderbolt 167 (E)*
Digiface USB: 18 (X), 35 (G)
Digiface AVB: 260*
Digiface Dante: 57*
Digiface Ravenna: 55
Digiface AES: USB 47 MCU 17 CC 11
Release date
2024-05-03
Mac Firmware Update for Digiface AVB
Mac Firmware Update Tool for Digiface AVB, v 260.
Release date
2024-04-29
Windows Flash Update Tool for Fireface UFX+, Digiface AVB, Digiface Dante - Nicht aktiv
Update to firmware revision UFX+: TB 110, DSP 46, USB 54 (AKM), TB 164, USB 68 (ESS). Digiface AVB: 244. Digiface Dante: 45.
Release date
2022-04-10
Mac OS X
Release date
Download
Release date
2024-04-29
macOS 11 or up USB Series DriverKit Driver
macOS 11 or up (Big Sur, Monterey, Ventura and up) Check OS Version USB series DriverKit driver, v. 4.10.
Release date
2024-01-18
macOS 10.12 up to 10.15 driver for Digiface AVB and Dante
version 3.223 with added USB-Ethernet (network) driver. Compatible to 10.12 up to 10.15.x. Please also install the RME AVB Controller for Digiface AVB.
Release date
2024-01-17
macOS 11 and up USB Series Kernel Extension Driver
USB 2/3 Kernel Extension driver for macOS 11 ( Big Sur, Monterey, Ventura and up) Check OS Version. Version 3.31. Supports Intel and Mx.
Release date
2024-01-17
macOS 10.12 up to 10.15 driver for Fireface UFX / UFX+ / UFX III, UFX II, 802, UCX, UCX II, UC, Babyface, Babyface Pro, MADIface XT/USB/Pro, Digiface USB/AES/Dante/Ravenna
version 3.223. Compatible to 10.12 (macOS Sierra) up to 10.15 (macOS Catalina) Check OS Version. Mx users please download macOS 11 and up USB Series Driver.
Release date
2024-01-16
RME Network Interface for Digiface AVB and Digiface Dante
RME Network interface for Digiface AVB and Digiface Dante, for Mac OS X 10.14 and up, Intel/Mx compatible. See readme for important notes and usage.
Release date
2023-06-22
Windows
Release date
Download
MADIface Pro: 73
OctaMic XTC: 47/26
Digiface AVB: 260*
Digiface Dante: 57*
Release date
2024-05-03
Release date
2022-04-10
Windows 10
Release date
Download
Windows USB combo-driver installer for Digiface AVB and Digiface Dante
Version 0.9831. Package includes network driver and AVB Controller 0.9596. Windows 8 and up.
Release date
2024-01-11
Windows 11
Release date
Download
Release date
2024-01-11
Windows 8
Release date
Download
Release date
2024-01-11
Mac OS X
Release date
Download
TotalMix FX Mac latest version (single file download)
TotalMix FX V 1.93. This zip includes only TotalMix FX, to update TotalMix when using older drivers that come with an older TotalMix FX version.
Release date
2024-02-10
Download
tmfx_mac_193.zip
RME AVB Package for Digiface AVB, macOS Sierra and up
Mac AVB package combo-installer, including AVB Controller version 09597, latest netifc version, and WireShark extension.
Release date
2024-01-18
TotalMix Remote Mac
TotalMix Remote V 1.40 - App to remote control TotalMix FX via ethernet and WiFi from other devices with Mac OS 10.12 or up. Universal Binary, supports Intel and Mx. Please note: can not be run on the same computer where the host TotalMix FX is used. This download is not TotalMix FX, which is part of the driver installation.
Release date
2024-01-17
RME AVB Controller for Digiface AVB, macOS Sierra and up
Version: 09574. Outdated, please use the download RME AVB Package.
Release date
2023-06-22
Windows
Release date
Download
TotalMix FX Windows latest version (single file download)
Release date
2024-02-10
Download
tmfx_win_193.zip
TotalMix Remote Windows
TotalMix Remote V 1.40 - Program to remote control TotalMix FX via ethernet and WiFi from other devices with Windows OS (PC, Tablet). Please note: can not be run on the same computer where the host TotalMix FX is used. This download is not TotalMix FX, which is part of the driver installation.
Release date
2024-01-17
Mac OS X
Release date
Download
DigiCheck NG macOS
Universal binary, runs natively on Intel and M1 machines. DigiCheck NG V 0.90 requires macOS 10.13 (High Sierra) or up.
Release date
2023-06-27
DIGICheck 0.73 Mac
Release date
2017-09-14
Download
dc_073_mac.zip
Windows
Release date
Download
DIGICheck 5.96 Win
Release date
2023-01-13
Download
dc_596_win.zip
Back
Manuals
Digiface AVB
Product
Description
Download PDF
Digiface AVB
Manual for Digiface AVB, version 1.41, 01/2021
Product Images
Media Material
Back
